Hot Topic (More than 10 Replies) Moving nodes using Keys (Read 9162 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Aug 17th, 2012 at 12:25pm
dear stoyo,
        i want to move the nodes up,down,left and right using keys. but i am not able to catch the keys "diagramView_KeyDown" kindly help
if you want something then go and grab it
Re: Moving nodes using Keys
Reply #1 - Aug 17th, 2012 at 1:24pm
The Windows Forms framework does not raise KeyDown for arrow keys. You can detect them using PreviewKeyDown instead:
http://mindfusion.eu/Forum/YaBB.pl?num=1323665629/1#1
madhan1
FROM EVERY ONE ..
Reply #2 - Aug 18th, 2012 at 4:30am
Thanks stoyo,
             it works only first time. when i am press the left key continuously the event is not fired. kindly help
Reply #3 - Aug 20th, 2012 at 8:04am
It is raised continuously in my test project. If it is raised only once in your application, perhaps the DiagramView loses the keyboard focus after the first key-press. You can verify that by adding a breakpoint to the DiagramView.Leave event handler; then you should be able to see in the call-stack window what exactly changes the focus.
madhan1
FROM EVERY ONE ..
Reply #4 - Aug 20th, 2012 at 11:25am
Dear stoyan,
My call stack,kindly check and help
Telephony.exe!Telephony.Form1.diagramView_Leave(object sender = {MindFusion.Diagramming.WinForms.DiagramView}, System.EventArgs e = {System.EventArgs}) Line 16754      C#
     System.Windows.Forms.dll!System.Windows.Forms.Control.OnLeave(System.EventArgs e) + 0x70 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Control.NotifyLeave() + 0x20 bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.UpdateFocusedCont
rol() + 0x2e2 bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.AssignActiveContr
olInternal(System.Windows.Forms.Control value = {System.Windows.Forms.PropertyGrid}) + 0x54 bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.ActivateControlIn
ternal(System.Windows.Forms.Control control, bool originator = false) + 0x76 bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.SetActiveControlI
nternal(System.Windows.Forms.Control value = {System.Windows.Forms.PropertyGrid}) + 0x73 bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.SetActiveControl(
System.Windows.Forms.Control ctl) + 0x33 bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.ActiveControl.set
(System.Windows.Forms.Control value) + 0x5 bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.Select(bool directed = true, bool forward = true) + 0x42 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Control.SelectNextControl(System.W
indows.Forms.Control ctl, bool forward, bool tabStopOnly, bool nested, bool wrap) + 0x7b bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.ProcessArrowKey(b
ool forward) + 0x3f bytes
     System.Windows.Forms.dll!System.Windows.Forms.ContainerControl.ProcessDialogKey(
System.Windows.Forms.Keys keyData = LButton | RButton | MButton | Space) + 0x6c bytes
     System.Windows.Forms.dll!System.Windows.Forms.Form.ProcessDialogKey(System.Windo
ws.Forms.Keys keyData) + 0xf8 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Control.ProcessDialogKey(System.Wi
ndows.Forms.Keys keyData) + 0x16 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Control.PreProcessMessage(ref System.Windows.Forms.Message msg) + 0xe2 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Control.PreProcessControlMessageIn
ternal(System.Windows.Forms.Control target = {MindFusion.Diagramming.WinForms.DiagramView}, ref System.Windows.Forms.Message msg = {System.Windows.Forms.Message}) + 0x101 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.PreTrans
lateMessage(ref System.Windows.Forms.NativeMethods.MSG msg = {System.Windows.Forms.NativeMethods.MSG}) + 0xf6 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.System.W
indows.Forms.UnsafeNativeMethods.IMsoComponent.FPreTranslateMessage(ref System.Windows.Forms.NativeMethods.MSG msg) + 0x5 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Application.ComponentManager.Syste
m.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(int dwComponentID, int reason = -1, int pvLoopData = 0) + 0x22e bytes
     System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.RunMessa
geLoopInner(int reason = -1, System.Windows.Forms.ApplicationContext context = {System.Windows.Forms.ApplicationContext}) + 0x177 bytes
geLoop(int reason, System.Windows.Forms.ApplicationContext context) + 0x61 bytes
     System.Windows.Forms.dll!System.Windows.Forms.Application.Run(System.Windows.For
ms.Form mainForm) + 0x31 bytes
     Telephony.exe!Telephony.Form1.Main(string[] args = {string[0]}) Line 1919 + 0x2d bytes      C#
     [Native to Managed Transition]
     [Managed to Native Transition]
     mscorlib.dll!System.AppDomain.ExecuteAssembly(string assemblyFile, System.Security.Policy.Evidence assemblySecurity, string[] args) + 0x3a bytes
     Microsoft.VisualStudio.HostingProcess.Utilities.dll!Microsoft.VisualStudio.Hosti
ngProcess.HostProc.RunUsersAssembly() + 0x2b bytes
     mscorlib.dll!System.Threading.ThreadHelper.ThreadStart_Context(object state) + 0x66 bytes
     mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionCon
text executionContext, System.Threading.ContextCallback callback, object state) + 0x6f bytes
Reply #5 - Aug 21st, 2012 at 7:01am
There's a ContainerControl.ProcessArrowKey method that handles the arrow keys and calls UpdateFocusedControl, which I suppose is what moves the focus away from the view. ContainerControl is a base for UserControl; if you have placed the DiagramView inside a user control, check this SO post:
http://stackoverflow.com/questions/6177201/how-to-prevent-usercontrol-form-handl...
madhan1
FROM EVERY ONE ..
Reply #6 - Aug 21st, 2012 at 8:34am
Dear stoyan,
              Thanks a lot,it works fine.
But i am not able to move the input node (shape node and Table combined ) and not able to move multiple nodes at a same time
madhan1
FROM EVERY ONE ..
Reply #7 - Aug 23rd, 2012 at 4:33am
Hi stoyan,
        is it possible to do.give some ideas so that i will try.
Reply #8 - Aug 23rd, 2012 at 6:42am
Ideas about what?
madhan1
FROM EVERY ONE ..
Reply #9 - Aug 23rd, 2012 at 7:18am
moving multiple selected nodes
Reply #10 - Aug 23rd, 2012 at 8:07am
You can get a list of selected nodes through diagram.Selection.Nodes.
madhan1
FROM EVERY ONE ..
Reply #11 - Aug 23rd, 2012 at 10:18am
Thanks stoyan,
           it worked Smiley
