Normal Topic Tree Layout nodes out of diagram view (Read 2066 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Aug 25th, 2012 at 9:25am
dear stoyan,
today i download the 5.8 version and try the Treelayout sample. still the left nodes is out side of the diagram view. i believe i rise this issue in 5.3.3 aslo. kindly check
for your reference i have add the screen also
if you want something then go and grab it
Re: Tree Layout nodes out of diagram view
Reply #1 - Aug 27th, 2012 at 6:21am
You will have to either set KeepRootPosition to false or move the root node to the right before applying TreeLayout.
