Normal Topic How to make the diagram view in readonly mode? (Read 2029 times)
Homam
Aug 28th, 2012 at 10:23am
How to make the diagram view in readonly mode? Selecting nodes is allowed but not adding new nor moving nor connecting/disconnecting any of its objects.
Behavior.Modefy: Prevents creating new nodes, allows selection but it allows moving the nodes which is undesirable.
Behavior.None: Prevents everything including selection which is required in my case.
Re: How to make the diagram view in readonly mode?
Reply #1 - Aug 28th, 2012 at 10:30am
You could create a custom behavior class that always returns null from StartDraw, or do one of the following with standard behaviors:
- Behavior.Modify: set args.Cancel from the NodeStartModifying and LinkStartModifying events;
- Behavior.None: set args.Node.Selected / Link.Selected from NodeClicked and LinkClicked events;
Homam
Reply #2 - Aug 28th, 2012 at 4:13pm
It helps, thanks.
