Normal Topic SelectionMoving event (Read 1634 times)
CanadaProgrammer
Aug 28th, 2012 at 4:13pm
Select 2 shapes, a node and a link, then move these shapes, then release left button of mouse, then SelectionMoved event is raised. In event SelectionMoving, if I set e.Cancel to true, then release left button of mouse, at this moment is there any event will be raised?
In the help ducument, there is a sentence to describe SelectionMoving event like below:
The event is raised once again when the mouse button is released.
It sounds that if I release button then the event will be raised and I am sure this is last time to raise this event. So how to know this is last time to raise SelectionMoving event?
Re: SelectionMoving event
Reply #1 - Aug 29th, 2012 at 9:16am
You could check the left mouse button state:
private void diagram_SelectionMoving(object sender, ValidationEventArgs e)
	Debug.WriteLine("selection moving");
	if ((MouseButtons & MouseButtons.Left) == 0)
		Debug.WriteLine("last time");
