Hello. The problem is following. When I remove link between 2 nodes inherited from ShapeNode and try to make new link between these nodes I catch the following exception: 29.08.2012 13:46:29. Unhandled exception catched.
System.Security.VerificationException: Operation could destabilize the runtime. at A.TJ`1..ctor(Int32 A) at A.QJ.X(NJ A, AK B, NJ C, AK D) at MindFusion.Diagramming.Wpf.QuickRouter.H(DiagramLink A, QJ B, List`1 C) at MindFusion.Diagramming.Wpf.QuickRouter.H(DiagramLink A, QJ B) at MindFusion.Diagramming.Wpf.QuickRouter.RouteLink(DiagramLink link) at MindFusion.Diagramming.Wpf.DiagramLink.JS(Boolean A, ConnectionPoint B, ConnectionPoint C, Boolean D, DiagramItemCollection E) at MindFusion.Diagramming.Wpf.DiagramLink.JS(Boolean A, Boolean B, DiagramItemCollection C) at MindFusion.Diagramming.Wpf.DiagramLink.Route() at Technologist.TPDEDiagram.OnDiagram_LinkCreated(Object sender, LinkEventArgs e) in D:\Work\TPDE\tpde4\TPDEDiagram_EventHadlers.cs:line 285 at MindFusion.Diagramming.Wpf.Diagram.OnLinkCreated(LinkEventArgs e) at MindFusion.Diagramming.Wpf.Diagram.RaiseCreated(DiagramItem item) at MindFusion.Diagramming.Wpf.InteractionState.Complete(Point point, Diagram diagram) at MindFusion.Diagramming.Wpf.Behaviors.BehaviorBase.OnMouseUp(Point mousePosition, MouseButton mouseButton) at Technologist.LinkBehavior.OnMouseUp(Point mousePosition, MouseButton mouseButton) in D:\Work\TPDE\tpde4\LinkBehavior.cs:line 336 at MindFusion.Diagramming.Wpf.Diagram.TN(MouseButtonEventArgs A, Point B) at MindFusion.Diagramming.Wpf.Diagram.OnPreviewMouseUp(MouseButtonEventArgs e) at System.Windows.UIElement.OnPreviewMouseUpThunk(Object sender, MouseButtonEventArgs e) at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
On Windows XP this problem is absent.
