Normal Topic "Could not load file or assembly 'MindFusion.Graphs' " is thrown.. what I'm supposed to do? (Read 3549 times)
Homam
Sep 9th, 2012 at 8:01am
I'm using the Diagram control in a WPF application. The following exception is thrown in runtime:
Could not load file or assembly 'MindFusion.Graphs, Version=2.2.0.13651, Culture=neutral, PublicKeyToken=0d09f0b4914ade28' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Knowing that I added references for:
MindFusion.Common
              .Diagramming
              .Diagramming.Wpf
              .Graphs
What I'm supposed to do?
Re: "Could not load file or assembly 'MindFusion.Graphs' " is thrown.. what I'm supposed to do?
Reply #1 - Sep 10th, 2012 at 6:52am
Quote:
.Diagramming
.Diagramming.Wpf
Do you mean you are using both the Windows Forms and the WPF versions of the control in the same project? If that's not intended, remove one of the assemblies and ensure graphs.dll is referenced from the same folder as the remaining diagramming assembly.
If you need to use both WinForms and WPF assemblies, you might have to install an older version for one of them that was built against the same graphs.dll version. Having close release dates as listed at http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_news usually means both controls will use the same version of shared assemblies.
