Normal Topic How to display HTML TEXT in a node's ToolTip (Read 1583 times)
ncepu
Sep 14th, 2012 at 12:21am
I want to display some complex text in a tooltip,for example,different colors or show a simple table in a tooltip.
If tooltip cant achieve it,how can achieve it?
Re: How to display HTML TEXT in a node's ToolTip
Reply #1 - Sep 14th, 2012 at 11:04am
You will have to implement such tooltips yourself, see the example here:
http://social.msdn.microsoft.com/Forums/hu-HU/winforms/thread/a689911e-56ca-4744...
You could show them in response to the NodePointed event. I suppose you might also use a temporary ShapeNode or TableNode, with styled text enabled, to display the tooltip information.
