Normal Topic TableNode Rotation (Read 1343 times)
ncepu
TableNode Rotation
Sep 15th, 2012 at 12:41pm
I want to rotate the TableNode like the ShapeNode,How can I achieve it.For the shapenode,I only to do is set the RotationAngle property.
Thanks in advance
Re: TableNode Rotation
Reply #1 - Sep 15th, 2012 at 4:14pm
Rotation of all types of nodes is supported by version 6 of the control:
http://mindfusion.eu/Forum/YaBB.pl?num=1344345191
With older versions you can rotate only ShapeNodes, though I suppose you could show tabular data inside them with some custom drawing.
