Normal Topic ym (Read 1453 times)
Homam
ym
Sep 24th, 2012 at 9:01am
In my diagram, I noticed that if the Dynamic property is set to true for links, the rout would be better. The only problem I have is that how to make sure that only one link related to every anchor point.
The first image in the attachment isn't acceptable. but the second one is OK.
Re: ym
Reply #1 - Sep 24th, 2012 at 5:09pm
The Dynamic property will only select the nearest anchor point, it can't be limited to one link per point at this time. You could try using the ReassignAnchorPoints method instead, e.g. call it from events such as NodeModified, LinkModified (when origin or destination changes) etc:
private void diagram_NodeModified(object sender, NodeEventArgs e)
	e.Node.ReassignAnchorPoints();
	diagram.RouteAllLinks();
Homam
Re: ym
Reply #2 - Sep 25th, 2012 at 11:09am
It worked, thanks.
