Normal Topic How to move an activity from any point - not only the border? (Read 3078 times)
Homam
Sep 25th, 2012 at 11:10am
I'd like to be able to move the node by moving it from any point - not only the border. How to accomplish that?
Lyubo
MindFusion team
Re: How to move an activity from any point - not only the border?
Reply #1 - Sep 25th, 2012 at 12:09pm
Try setting the node's HandlesStyle property to EasyMove.
Here's a link in the help files, which describes all available options: http://www.mindfusion.eu/onlinehelp/flowchartnet/index.htm?T_MindFusion_Diagramm....
Lyubo
Homam
Reply #2 - Sep 26th, 2012 at 9:33am
it worked only in the border and on the central label. But the it's not able to move the node from the other inner points.
Lyubo
MindFusion team
Reply #3 - Sep 26th, 2012 at 10:50am
When you select the node, do you see a round handle at the node's center?
If not, please check if you're not loading some file, that restores a previously set HandlesStyle value; or maybe EasyMove gets overwritten by a later assignment somewhere in your code.
You could also attach a handler to the Diagram.NodeSelected event and check the actual value on node selection (the following will output the value in the Visual Studio Output window):
private void diagram_NodeSelected(object sender, NodeEventArgs e)
    System.Diagnostics.Debug.WriteLine(e.Node.HandlesStyle);
Homam
Reply #4 - Sep 26th, 2012 at 11:35am
Well, thank you for replying.
I checked the value and it was "HatchHandles" for the HandlesStyle. And view.ControlHandlesStyle is "EasyMove".
Is it wired?
Lyubo
MindFusion team
Reply #5 - Sep 26th, 2012 at 11:46am
DiagramView.ControlHandlesStyle provides a default value for newly created ControlNode instances in the diagram.
If you are using ShapeNodes (if I recall correctly from a sample you sent us before), set Diagram.ShapeHandlesStyle instead.
For other node types, handle the NodeCreating event, and assign the value from there.
Lyubo
Homam
Reply #6 - Sep 26th, 2012 at 11:53am
It worked well. Thank you.
Sorry.. I'm asking too much - the last question here.. Is it possible to remove this "small area in the center" since I'm using anchor points on the border to create links?
Lyubo
MindFusion team
Reply #7 - Sep 26th, 2012 at 12:13pm
You could try if HandlesStyle.InvisibleMove fits the requirements.
Other than that, there's the Custom option which lets you perform custom drawing and hit testing of the selection handles yourself.
I hope this helps,
Lyubo
