Normal Topic Execution hangs on links operations when using Lanes (Read 1542 times)
Psybeam
It's super effective!
Sep 25th, 2012 at 12:19pm
Greetings.
I wasn't sure if I should have created this topic here or in Bug Reports, so please move it if it doesn't fit here.
I've decided to use Lanes Grid in the C# application I'm working on, but now it freezes on any operation involving links. If I disable the Lanes, the same code works fine. The code on which the application gets stuck is not mine - what hangs the app is internal MindFusion methods.
I.e., if I pause the debugging, I can see that it's stuck at the lines like
m_diagram.Links.Add(m_diagram, ParentNode, Node)
or
m_diagram.RouteAllLinks();
I have looked into the sample Lanes application and have not found any reason why would links work there but do not in my case.
Here's the code I initialize my grid with:
Grid grid = m_diagram.LaneGrid;
      HeaderCollection columns = grid.ColumnHeaders;
      grid.MinHeaderSize = 50;
      grid.HookHeaders = false;
      grid.HeadersOnTop = false;
      grid.ColumnHeadersHeights = new float[] { 10 };
      grid.AlignCells = false;
      grid.AllowResizeHeaders = false;
      columns.Add(new Header("1"));
      columns.Add(new Header("2"));
      columns.Add(new Header("3"));
      columns.Add(new Header("4"));
      columns.Add(new Header("5"));
      columns.Add(new Header("6"));
      grid.ColumnCount = 6;
      grid.RowCount = 1;
      grid.RowHeaders[0].Style.BackgroundBrush = new SolidBrush( Color.Gainsboro );
      grid.RowHeaders[0].Width = 0;
      for (int i = 0; i < 6; i++)
        Header column = grid.GetColumn(i);
        column.Style.BackgroundBrush = new SolidBrush(Color.Gainsboro);
        column.Style.BottomBorderPen = null;
        column.Style.LeftBorderPen =
          column.Style.TopBorderPen =
            column.Style.RightBorderPen = new Pen(Color.Gainsboro, 0.5f);
        column.TitleFont = new Font( "Tahoma", 9.75f, FontStyle.Bold );
        grid[column, null].Style.BackgroundBrush =
          new SolidBrush(Color.WhiteSmoke);
        grid[column, null].Style.BottomBorderPen =
          grid[column, null].Style.LeftBorderPen =
            grid[column, null].Style.RightBorderPen = new Pen(Color.Gainsboro, 0.5f);
        grid[column, null].Style.TopBorderPen = null;
        if(i == 0)
          grid[column, null].Style.LeftBorderPen = null;
          grid[column, null].Style.BottomBorderPen = null;
      m_diagram.Bounds = new RectangleF(0, 0, 300, Single.NaN);
      m_diagram.EnableLanes = true;
Any thoughts?
Lyubo
MindFusion team
Re: Execution hangs on links operations when using Lanes
Reply #1 - Sep 25th, 2012 at 12:51pm
NaN values are not supported for Bounds coordinates and in this case the routing algorithm gets confused by this line in your code:
Initialize the rectangle with a number value and routing should work as expected.
I hope this is helpful.
Lyubo
Psybeam
Reply #2 - Sep 26th, 2012 at 9:57am
That was exactly it! Thank you! Smiley
Issue solved! Smiley
