Normal Topic Problem in printing the diagram (Read 1216 times)
Homam
Sep 30th, 2012 at 1:38pm
I tried to print the diagram by this code:
Code (Java)
 view.PrintOptions.DocumentName = ProcessName;
            view.PrintOptions.EnableImages = true;
            view.PrintOptions.EnableInterior = true;
            view.PrintOptions.EnableShadows = true;
            view.PrintOptions.Scale = 100;
            view.PrintPreview();
The result is in the attached.
Re: Problem in printing the diagram
Reply #1 - Oct 1st, 2012 at 5:47am
This happens when MeasureUnit is set to Pixel since printers' pixels are much smaller. You will have to compensate for the higher printer resolution by setting larger PrintOptions.Scale, or otherwise switch to a logical unit such as Point. If you don't want to change the unit permanently, you could copy the diagram, change MeasureUnit on the copy and print it from a hidden view.
