Normal Topic Export to visio (Read 2245 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Export to visio
Oct 1st, 2012 at 10:04am
Dear stoyan,
            i am trying to export the objects to visio using the "PDF exporter" sample.
            saveFileDialog.DefaultExt = "visio";
            saveFileDialog.Filter = "visio files|*.vsd";
                 if (saveFileDialog.ShowDialog() == DialogResult.OK)
                MindFusion.Diagramming.Export.VisioExporter visioexp = new Export.VisioExporter();
                //visioexp.ExportImagesAsGroups = false;
                visioexp.Export(diagramView1.Diagram, saveFileDialog.FileName);
but i am getting a error
Could not find file 'C:\Documents and Settings\LBITIND\Desktop\VisioExport.vxt'.
FYI : i am trying to save the file in desktop as testing.vsd
if you want something then go and grab it
Re: Export to visio
Reply #1 - Oct 1st, 2012 at 10:38am
You should copy VisioExport.vxt to your project's output folder. It contains some skeleton vdx markup code used by the exporter. If VisioExport.vxt isn't located in the same folder as the executable file, set VisioExpoter.TemplatePath to point to it. Also note that the exporter does not create binary format .vsd files, but xml format .vdx files.
madhan1
FROM EVERY ONE ..
Re: Export to visio
Reply #2 - Oct 1st, 2012 at 12:20pm
Sorry stoyan,
            i did n't find any "VisioExport.vxt " file in my system?
Re: Export to visio
Reply #3 - Oct 1st, 2012 at 12:38pm
There should be one in the bin subfolder of the flowchart.net's installation root folder.
madhan1
FROM EVERY ONE ..
Re: Export to visio
Reply #4 - Oct 1st, 2012 at 3:19pm
Thanks stoyan
