Normal Topic Does diagram.RoutAllLinks affect the links that their property of AutoRout is set to false? (Read 1757 times)
Homam
Oct 2nd, 2012 at 6:44am
Re: Does diagram.RoutAllLinks affect the links that their property of AutoRout is set to false?
Reply #1 - Oct 2nd, 2012 at 7:45am
Yes, calling diagram.RouteAll() or link.Route() will reroute links even if there AutoRoute flag is set to false.
Homam
Reply #2 - Oct 2nd, 2012 at 8:01am
When I create a node, I create with it two free-end links to be handlers. When I call RoutAllLinks(), these unrelated links move and appears in a wired form although their AutoRout property is set to false.
Is there a way to ignore them in RoutAllLinks()?
Another question may solve my problem: Is there any extra processing in RoutAllLinks method or it's only a loop on all links and call Rout for each one?
Reply #3 - Oct 2nd, 2012 at 8:13am
RouteAll does some extra processing when using QuickRouter - it pulls apart link segments that would overlap. You could call diagram.LinkRouter.RouteLinks(collection) to route only specific links while retaining that behavior.
