Normal Topic javaApplet client-side events reference or tutorial (Read 1528 times)
saad
Oct 16th, 2012 at 1:36am
I was following the javascript diagramming reference and the piece of code below does not seem to work in javaapplet client side events.
Code (Javascript)
    // paint all nodes with light blue color
    diagram.nodes.forEach(function (node)
        node.setBrush(scriptHelper.createSolidBrush(205, 92, 92));
Is the javascript reference built for imageMap?
Is there a way to enable javascript intellisense in VS 2010?
Re: javaApplet client-side events reference or tutorial
Reply #1 - Oct 16th, 2012 at 6:26am
The JavaScript reference is for ClientSideMode = Canvas. You can find the API for JavaApplet documented here:
http://www.mindfusion.eu/onlinehelp/netdiagram/index.htm?refcom_mindfusion_diagr...
forEach is a method of JavaScript arrays and won't work with Java collections. You can iterate over the Java diagram nodes like this:
for (var i = 0; i < diagram.getNodes().size(); ++i)
      var node = diagram.getNodes().get(i);
