Normal Topic Multiple Version Support (Read 7388 times)
shibusr
Oct 18th, 2012 at 12:34pm
  Can we have multiple version of flowchart control in one PC?. e.g. 4.0 and 4.5?
Regards
Shibu
Indus Systems Inc
Re: Multiple Version Support
Reply #1 - Oct 18th, 2012 at 12:43pm
You can, via the Windows SxS feature, but I don't think this will work from a web page as you mentioned you are using the control earlier:
http://msdn.microsoft.com/en-us/library/windows/desktop/dd408052(v=vs.85).aspx
You can use different versions from 32-bit / 64-builds of the control though, since they are described in different parts of the Windows registry.
shibusr
Reply #2 - Oct 18th, 2012 at 12:50pm
   It not required for server side. but we need it in client PCS. We are providing client set up for our application.
Our Scenario is that, we have two different application url with 32 bit and 64 bit. Some our users need both url works which leads to require both versions of dll. Can we register two versions of dll 4.0 and 4.5.
Regards
Shibu
Indus Systems Inc
Reply #3 - Oct 18th, 2012 at 12:54pm
If you need version 4.0 for the 32bit dll and version 4.5 for the 64bit dll, it will work since they are registered in separate parts of the Windows registry.
shibusr
Reply #4 - Oct 19th, 2012 at 5:30am
I mean that for client machine. Not in server. It is not working in client side. It shows script error in browser when we registerd bot version in client pc. It is working fine with 32 bit url but not for 64 bit URL.
Another question we have is that can we distribut your setup as part of our application? Is it legal?
Regards
Shibu
Indus Systems Inc
Reply #5 - Oct 19th, 2012 at 7:13am
You shouldn't distribute the control's installers, and you shouldn't need that for client installations anyway.
I can't see any problem registering different versions of the 32 and 64 bit builds of flowchartx.dll. Are you sure there isn't some other problem with your 64-bit URL? Does it work if you haven't installed 32-bit version previously?
shibusr
Reply #6 - Oct 19th, 2012 at 9:30am
hello,
can we distribute dlls. I mean if we are providing our own setup to register dll and licence key in customers server?
64 bit SVG Export is available?
Regards
Shibu
Indus Systems Inc
Reply #7 - Oct 19th, 2012 at 11:30am
You can distribute the dll files naturally, but you shouldn't distribute the design time license key to your customers. We have some other methods of checking licenses built into the control; contact us at support@mindfusion.eu with your company's name to get details.
There's no 64bit version of SvgExporter available at this time.
