Normal Topic CustomDraw Bug? Draw handler gets fired continuously. (Read 3629 times)
Achim
MindFusion rocks!
Oct 23rd, 2012 at 1:09pm
Hi there,
I was wondering why some strange things happened in my application. I found out that the Draw event handler gets fired continuously when I'm using this code:
Code (C++)
            calendar1.CustomDraw |= CustomDrawElements.ResourceViewItem;
            calendar1.Draw += delegate(object sender, DrawEventArgs e)
                                      //propertyGrid1.SelectedObject = e;
                                      if (e.Element == CustomDrawElements.ResourceViewItem)
                                          counter++;
                                          ClientApplication.INSTANCE.AppFrame.StatusBar.Status = counter.ToString();
                                          int distance = e.GetDistance(sender as Calendar, e.Item.StartTime.AddHours(3));
                                          if (distance >= 0)
                                              e.Graphics.DrawLine(Pens.Aquamarine, e.Bounds.Left + distance, e.Bounds.Top,
        e.Bounds.Left + distance, e.Bounds.Bottom);
The counter variable is static to monitor the calls. In 10 seconds the counter was at about 500  Shocked
Any help on this?
Best regards
Achim
Re: CustomDraw Bug? Draw handler gets fired continuously.
Reply #1 - Oct 23rd, 2012 at 3:22pm
I presume that the items are getting repainted as a result of the mouse being moved within the control. You can turn this off by disabling the extended item styles (Calendar.ItemSettings.UseExtendedStyles = Disabled). I will see if we can improve this by repainting the items only when they actually change state during mouse moves.
If the event is raised even when the mouse is not moved, there must be some code that causes the control to repaint. In this case, I will appreciate it if you can send me a small application, which reproduces this issue.
Achim
MindFusion rocks!
Reply #2 - Oct 24th, 2012 at 7:34am
Hi Meppy,
I made a small test application and everything worked fine. After a little search I found out, that the double buffering feature in my application caused the continuous firing of the paint event (but only after an item was created in the ResourceView).
Code (C++)
        protected override CreateParams CreateParams
            //NOTE: this is taken from: http://www.angryhacker.com/blog/archive/2010/07/21/how-to-get-rid-of-flicker-on-windows-forms-applications.aspx
            get
                if (ClientApplication.INSTANCE.EnableDoubleBuffer)
                    // Activate double buffering at the form level.  All child controls will be double buffered as well.
                    CreateParams cp = base.CreateParams;
                    cp.ExStyle |= 0x02000000; // WS_EX_COMPOSITED
                    return cp;
                return base.CreateParams;
For now I disabled the double buffer feature. Maybe you can test it and find the reason why the ResourceView does not work with this.
Best regards
Achim
Reply #3 - Oct 24th, 2012 at 8:08am
Hi again,
Are you sure that the double-buffering flag alone causes the Draw event to be raised continuously? Turning this flag on in my application seems to have no effect on the event.
In any case, we have made some improvements to how items are repainted during mouse moves. Repaints should now only occur when an item actually changes its state. Trial version of the new assemblies can be downloaded from here.
You can also try setting Calendar.EnableOptimization to true. This will cause items to be cached and they will be repainted only when their appearance or size changes.
Achim
MindFusion rocks!
Reply #4 - Oct 26th, 2012 at 8:12am
Hi Meppy,
hm. It seems to be a combination of the double buffering feature and anything else in my application but I have not found it yet. I've tried the EnableOptimization flag but then my custom drawing produce weird results.
So far I disabled the double buffering which works fine for me. Maybe after my holidays I'll go back on it and try to find out what in combination with double buffering makes the event go wild.
I also have to try the new assemblies and test the redrawing in combination with my custom drawings on the items.
Best regards
Achim
