Normal Topic Set Shape Text on NodeCreated (Read 3146 times)
saad
Oct 24th, 2012 at 3:05am
How do I set the text of the shape when node is created?
So far its like this:
 protected void diagramView_NodeCreated(object sender, NodeEventArgs e)
        // setting constraint on aspect ratio
        e.Node.Constraints.KeepRatio = true;
        // setting height
        e.Node.Resize(40,40);
        //ShapeNode node = e.Node;
        // setting node id
        e.Node.Id  = "new";
How do I set its text displayed ?
In any case the ID does not seem to be set.
Because I did this in Page_Load:
  // checking for any new node created and setting its Id to GUID and setting text
        foreach (ShapeNode node in diagramView.Diagram.Nodes)
            if (node.Id == "new")
                node.Id = System.Guid.NewGuid().ToString();
                node.Text = "Tag: ";
...and it just doesnt seem to catch the node.id.
Infact when I do this...
            string nodeID = node.Id.ToString();
            node.Text = nodeID;
...it stops the shapes from being placed onto diagramView from shapeListBox altogether!
saad
Re: Set Shape Text on NodeCreated
Reply #1 - Oct 24th, 2012 at 5:53am
This is how I temporarily solved it.
However I would appreciate a better solution, for some reason the iteration (foreach) seems quite inefficient to me:
        // setting height
        // setting shapenode text
        currNode = e.Node.ZIndex;
            if (node.ZIndex == currNode)
                node.Text = "Current node: " + currNode;
Reply #2 - Oct 24th, 2012 at 5:56am
Use the following pattern when you need to set node type -specific properties:
ShapeNode shapeNode = e.Node as ShapeNode;
if (shapeNode != null)
    shapeNode.Text = "node 1";
    shapeNode.Shape = Shapes.Decision;
TableNode tableNode = e.Node as TableNode;
if (tableNode != null)
saad
Reply #3 - Oct 24th, 2012 at 6:26am
Solved
Brilliant, thanks.
