Normal Topic Bit of blue background showing on diagramView (Read 2860 times)
saad
Oct 25th, 2012 at 3:17am
Cant seem to get rid of this.
Re: Bit of blue background showing on diagramView
Reply #1 - Oct 25th, 2012 at 6:24am
This is the diagram.BackBrush used to fill the diagram.Bounds rectangle. You could set the brush to a solid white one, or make sure your nodes cover the entire diagram.Bounds.
saad
Reply #2 - Oct 25th, 2012 at 6:34am
After dropping a shape on diagramView and deleting it, the blue backgrond goes away.
Reply #3 - Oct 25th, 2012 at 6:41am
If you have diagram.AutoResize enabled, Bounds will shrink or expand to fit items when you add or remove ones.
saad
Reply #4 - Oct 25th, 2012 at 6:48am
Solved.
Thanks, that worked.
