Normal Topic Problem setting Bounds.Y Coordinate (Read 2099 times)
saad
Oct 25th, 2012 at 10:14am
Doing this:
lastShapeNode.Bounds.Y = 10;
Getting this error:
Error      1      Cannot modify the return value of 'MindFusion.Diagramming.DiagramNode.Bounds' because it is not a variable
Re: Problem setting Bounds.Y Coordinate
Reply #1 - Oct 25th, 2012 at 10:21am
Since RectangleF is a struct, you must assign a new instance to Bounds:
lastShapeNode.Bounds = new RectangleF(x, 10, w, h);
saad
Reply #2 - Oct 25th, 2012 at 4:08pm
Solved.
Thanks, that worked.
Used it like this:
lastShapeNode.Bounds = new System.Drawing.RectangleF(lastShapeNode.Bounds.X, lastShapeNode.Bounds.Y, lastShapeNode.Bounds.Width, lastShapeNode.Bounds.Height - ((lastShapeNode.Bounds.Bottom) - (diagramPB.Bounds.Bottom))); //. ((diagramHeight / extVarStages) * 4);
