Normal Topic Make diagram size dynamic / changed when shape exceeds diagram bounds (Read 2219 times)
saad
Oct 26th, 2012 at 10:25pm
Is there a way to make the diagram size dynamic so that if a shape creeps out of bounds, the diagram height or width gets increased? AND, ideally decreased when its well within bounds?
Re: Make diagram size dynamic / changed when shape exceeds diagram bounds
Reply #1 - Oct 27th, 2012 at 8:10am
Set the Diagram.AutoResize property. I think you disabled it a few posts back because you wanted the diagram to stay as large as your lane nodes back then Smiley
saad
Reply #2 - Oct 27th, 2012 at 8:38am
I'll consider this solved.
I wanted only height to increase (as the lanes were added).
In protected void diagramView_NodeModified(object sender, NodeEventArgs e)
        // adjust DIAGRAM HEIGHT as lanes are added / dropped to compact the diagram around lanes
        // refering diagram
        //Diagram diagramPB = diagramView.Diagram;
        // finding last stage
        ShapeNode lastShapeNode = diagramPB.FindNodeById("Stage " + extVarStages) as ShapeNode;
        // check if last shape node's bottom is greater than diagram height,
        // if so increase diagram height to last shape node's bottom
        if (lastShapeNode.Bounds.Bottom > diagramHeight)
            diagramHeight = Convert.ToInt32(lastShapeNode.Bounds.Bottom);
            diagramPB.Bounds = new System.Drawing.RectangleF(0, 0, diagramWidth, diagramHeight);
        // check if last shape node's bottom is lesser than diagram height,
        // if so decrease diagram height to last shape node's bottom
        if (lastShapeNode.Bounds.Bottom < diagramHeight)
Might come to some use for someone so i thought i'd paste it.
