Normal Topic Multiple AttachTo not working (Read 2420 times)
saad
Oct 25th, 2012 at 8:38am
Code can be seen below. When both lines of code are used at same time, second one works. If second is commented out, first one does the job as required. Why?
 // attach current shapenode to previous shapenode
                    tempShape.AttachTo(prevShapeNode, AttachToNode.BottomCenter);
                    // attach previous shapenode to current shapenode
                    prevShapeNode.AttachTo(tempShape, AttachToNode.TopCenter);
saad
Re: Multiple AttachTo not working
Reply #1 - Oct 25th, 2012 at 9:21am
I temporarily solved this by restricting handles so that only BottomCenter would be enabled in each.
This is inefficient.
 // restricting lanes/stages handles so that only height can be adjusted by user.
                        // if first stage encountered: allow only bottom center handle
                        if (i == 0)
                            tempShape.EnabledHandles = AdjustmentHandles.ResizeBottomCenter;
                        // if last stage encountered: allow no handle
                        if (i == (extVarStages-1))
                            tempShape.EnabledHandles = AdjustmentHandles.None;
                        // for all other stages allow only bottom center handle
                        else
                            //tempShape.EnabledHandles = AdjustmentHandles.ResizeTopCenter | AdjustmentHandles.ResizeBottomCenter;
Reply #2 - Oct 25th, 2012 at 4:15pm
This should work for only two nodes. However, an attached node can have only one master node, so doing that from a loop for all 'lane' nodes will cause a second AttachTo for a node to detach from the previous master. If you need to move lanes  when one of them is resized, you can do that from the NodeModified event handler instead - starting the loop from the modified nodes' index + 1 and moving each next lane to the bottom of previous one.
saad
Reply #3 - Oct 30th, 2012 at 7:55pm
Solved
In page_load ... !ispostback
// Horizontal Lanes: create lanes based on stages
            // iterate while 'extVarStages' is reached
            for (int i = 0; i < extVarStages; i++)
                // defining y-axis with 'rectangleHeight' predefined variable
                // and multiplying it by the next lane to be created by sequence.
                // e.g if height is 2 then second shape would be at 2*2=4, 3rd would be 2*3=6
                // this would ensure they are placed sequentially one after another.
                ShapeNode tempShape = diagram.Factory.CreateShapeNode(0, rectangleHeight * i, diagramWidth, rectangleHeight);
                // set type of shape to rectangle to resemble a lane
                tempShape.Shape = Shapes.Rectangle;
                // name the shape concatenating the number of stage at end
                tempShape.Text = "Stage " + (Convert.ToInt32(i) + 1).ToString();
                // set Id of shape to that later on if for instance one lane is resized, another can be refered to for adjustment.
                // call the Id same as the text of the shape.
                tempShape.Id = "Stage " + (Convert.ToInt32(i) + 1).ToString();
                // set ZIndex so that the lane stays at bottom at all times below other shapes on diagramView.
                tempShape.ZBottom();
                // set color of shape
                tempShape.Brush = new MindFusion.Drawing.SolidBrush(System.Drawing.Color.GreenYellow);
                // disable self loops on lanes //TEST
                //// prevent links on lanes/stages
                //tempShape.AllowIncomingLinks = false;
                //tempShape.AllowOutgoingLinks = false;
                // attaching to previous stage and restricting handles if first or last stage
                // check if shape is greater than 0 (means greater than Stage 1)
                if (i > 0)
                    // get stage number of current stage (add by 1 as stages start from 1)
                    int currStageNum = i + 1;
                    //Shape prevStage = Shape.FromId("Stage " + (currStageNum - 1)) as Shape;
                    //ShapeNode pNode = ShapeNode.f
                    // reference previous shapenode
                    ShapeNode prevShapeNode = diagram.FindNodeById("Stage " + (currStageNum - 1)) as ShapeNode;
                    tempShape.AttachTo(prevShapeNode, AttachToNode.BottomCenter); // TEMP COMMENTED!!!
                    //prevShapeNode.AttachTo(tempShape, AttachToNode.TopCenter);
                if (i == 0)
                    //tempShape.EnabledHandles = AdjustmentHandles.ResizeBottomCenter;  // TEMP COMMENTED!!!
                // if last stage encountered: allow top center handle
                else if (i == (extVarStages - 1))
                    tempShape.EnabledHandles = AdjustmentHandles.ResizeTopCenter;
                // for all other stages allow only bottom center handle and top center handle
                else
                    tempShape.EnabledHandles = AdjustmentHandles.ResizeBottomCenter | AdjustmentHandles.ResizeTopCenter;
