Normal Topic ResourceView: Possible bug when item with custom type is cloned by the user. (Read 2940 times)
Achim
MindFusion rocks!
Oct 26th, 2012 at 8:07am
Hi there,
I am using the ResourceView with a custom Item type (derived from Appointment). Everything works fine until I am going to clone an item in the ResourceView holding the shift key down while clicking on the item. A new item is created but it seems to be of type Appointment. I've set the interactive item type to
calendarControl.InteractiveItemType = typeof (MarkableAppointment);
Maybe this is a bug or do I have to setup something I don't know?
Best regards
Achim
Re: ResourceView: Possible bug when item with custom type is cloned by the user.
Reply #1 - Oct 26th, 2012 at 8:44am
Have you overridden the Appointment.Clone method? You can have a look on how to do it properly in Tutorial #4 (the Interactive cloning section).
Achim
MindFusion rocks!
Reply #2 - Oct 26th, 2012 at 10:41am
Hi Meppy,
thank you very much - that's exactly what I needed.
Best regards
Achim
