Normal Topic Getting the dragging/layout status of an item during CustomDraw operations (Read 3211 times)
Achim
MindFusion rocks!
Oct 30th, 2012 at 8:41am
Hi there,
yeah, I'm diggin' deeper into custom drawing Smiley Today I have an issue happening when a custom drawn item is being moved while another item is dragged on the same resource. On the attached screenshot you can see what happens while dragging the other item: the small black/white arrow symbols appear, the custom drawn item disappears (which is the intended behavior) but the custom drawn text and icon are still there - a little bit weird positioned... Shocked
This is my code:
calendar.CustomDraw |= CustomDrawElements.ResourceViewItem | CustomDrawElements.ItemMoveBand;
            calendar.ItemDrawing += delegate(object sender, DrawEventArgs args)
                    if (args.Element == CustomDrawElements.ResourceViewItem)
                        var infoItem = args.Item as InfoItem;
                        if (infoItem != null)
                            args.Handled = true;
                            if (args.IsShadow) return;
                            var ds = getSet(infoItem.DisplayType);
                            var b = args.Bounds;
                            args.Graphics.FillRectangle(ds.BackBrush, b);
                            args.Graphics.FillRectangle(ds.BorderBrush, b.Left, b.Top, b.Width, 3);
                            args.Graphics.FillRectangle(ds.BorderBrush, b.Left, b.Bottom -3, b.Width, 3);
                            var y = args.Bounds.Top+(args.Bounds.Height - ds.Symbol.Height)/2;
                            args.Graphics.DrawImage(ds.Symbol, args.Bounds.Left + 3, y, ds.Symbol.Width, ds.Symbol.Height);
                            var offsetW = ds.Symbol.Width + 5;
                            var textBounds = new Rectangle(args.Bounds.X + offsetW, args.Bounds.Y,
                                                           args.Bounds.Width - offsetW, args.Bounds.Height);
                            args.Graphics.DrawString(args.Item.HeaderText,
                                args.Style.HeaderFont,
                                ds.TextBrush,
                                textBounds, ds.Format);
I'm looking for a way to detect the status of the layout in the custom drawing routing. So if I knew the item is not visible because the layout is going to change I could just return doing nothing.
Thanks in advance for any help on this
Achim
Re: Getting the dragging/layout status of an item during CustomDraw operations
Reply #1 - Oct 30th, 2012 at 9:36am
It appears that the ItemDrawing event is raised for out-of-the-view items with an empty Bounds as an argument. The following version should fix this:
https://mindfusion.eu/_temp/MindFusion.Scheduling.5.4.2.trial4.zip
Achim
MindFusion rocks!
Reply #2 - Oct 30th, 2012 at 9:43am
YEP! It does Smiley
Best regards and happy halloween
Achim
