Normal Topic How to delete ShapeNode or Link Programatically (Read 4655 times)
saad
Oct 30th, 2012 at 3:57pm
In imagemap server side asp.net code, how do you delete a shapenode or link, programatically?
saad
Re: How to delete ShapeNode or Link Programatically
Reply #1 - Oct 30th, 2012 at 7:38pm
My purpose was to delete a link if it was originating or its destination was a lane.
Here is how I did it.
In protected void diagramView_LinkCreated(object sender, LinkEventArgs e)
// refering diagram
        Diagram diagramPB = diagramView.Diagram;
 // delete / remove current link if its associated with a stage/lane
            // iterate through lanes/stages
            for (int i = 1; i <= extVarStages; i++)
                // reference current node (lane/stage) to compare with
                ShapeNode currShapeNode = diagramPB.FindNodeById("Stage " + i) as ShapeNode;
                // check if current links' origin or destination node is any stage/lane
                if (e.Link.Origin == currShapeNode | e.Link.Destination == currShapeNode)
                    // get index of current link
                    int indexOfCurrLink = diagramPB.Links.IndexOf(e.Link);
                    // if current link exists
                    if (diagramPB.Links.GetAt(indexOfCurrLink) != null)
                        // remove link from diagram at position specified by index of current link
                        diagramPB.Links.RemoveAt(indexOfCurrLink);
                        // refresh page while maintaining URL with any querystrings
                        Response.Redirect(Request.RawUrl);
« Last Edit: Oct 30th, 2012 at 9:19pm by saad »
saad
Reply #2 - Oct 30th, 2012 at 9:22pm
In above code i came up with i'm making a major mistake here:
In turn I changed it to:
UpdatePanel1.Update();
Which is fine except now the image of the arrow remains plastered on the screen.
This is not efficient.
Is there is a way to prevent a shapenode from having incoming or outgoing links?
Reply #3 - Oct 31st, 2012 at 7:40am
Deleting the newly created link from LinkCreated should look like this:
diagram.Links.Remove(e.Link);
without updating or redirecting anything afterwards. That doesn't show an arrow plastered on the screen in my test. Setting Locked = true for your lane nodes should prevent drawing links to them.
saad
Reply #4 - Oct 31st, 2012 at 7:42am
Solved
Excellent!
