Normal Topic Problem with GetAllOutgoingLinks().Clear() (Read 1320 times)
saad
Oct 30th, 2012 at 10:09pm
I'm having trouble implementing GetAllOutgoingLinks().Clear().
I'm trying to delete all outgoing (and preferably incoming) links from a certain shapenode.
Re: Problem with GetAllOutgoingLinks().Clear()
Reply #1 - Oct 31st, 2012 at 7:57am
You will have to remove them from diagram.Links, only then the links will disappear from the diagram (and will also be removed automatically from respective links collection of nodes).
