Normal Topic Containernode childs not responding to treelayout (Read 2773 times)
Rick Veens
Nov 12th, 2012 at 1:54pm
Hi im trying to layout a diagram containing containernodes and shapenodes.
When i run the arrange method on the diagram the nodes added to the containernode are node arranged and are put on each other.
The nodes in the containernode should be displayed one at a time vertically.
I also tried using a layout on the nodes contained in the diagramnode but it doesnt seem to be working.
I am using a tree layout.
Thanks in advance!
Re: Containernode childs not responding to treelayout
Reply #1 - Nov 12th, 2012 at 2:48pm
Layout classes do not arrange containers' children. You will have to apply layouts separately on each container; see an example here:
http://mindfusion.eu/Forum/YaBB.pl?num=1273515591/1#1
Rick Veens
Reply #2 - Nov 12th, 2012 at 3:18pm
Hi again,
Unfortunately it doesnt seem to be working.
            TreeLayout tl = new TreeLayout();
            tl.Direction = TreeLayoutDirection.LeftToRight;
            tl.NodeDistance = 10;
            tl.LinkStyle = TreeLayoutLinkType.Rounded;
            LayeredLayout layeredLayout = new LayeredLayout();
            layeredLayout.Orientation = MindFusion.Diagramming.Layout.Orientation.Horizontal;
            Arrange(diagram, tl, layeredLayout);
I copied the code on the page you linked and im using the Arrange method with 3 parameters.
Am i using the wrong layouts?
I dont seem to have the TopologicalLayout class.
Reply #3 - Nov 12th, 2012 at 5:09pm
What version of the control are you using?
Rick Veens
Reply #4 - Nov 13th, 2012 at 8:32am
Thanks for your response!
Stoyo wrote on Nov 12th, 2012 at 5:09pm:
I am using version 1.0.2826.18027.
Also the runtime version is v2.0.50727 according to the properties window.
Reply #5 - Nov 13th, 2012 at 10:44am
I suppose that old version might not support arranging multiple graphs from the layout.Arrange(items) method. Try adding some temporary links between the child nodes to make them a single graph, or loop over the children and set their Bounds to form a column instead of relying on a layout class.
