Normal Topic How to set nodes aligned to a grid? (Read 1023 times)
Homam
Nov 19th, 2012 at 2:22pm
How to prevent these shifts in the links? how to set the the nodes aligned to a grid?
Re: How to set nodes aligned to a grid?
Reply #1 - Nov 19th, 2012 at 2:43pm
Use the AlignPointToGrid method to find the grid point closest to a target point. The links should appear as straight lines if the nodes centers are on the same vertical line.
