Normal Topic Percentage node (Read 1127 times)
lyrock
Percentage node
Nov 28th, 2012 at 9:18pm
Is there a way to create a "percentage" node, whose value/display can be modified as shown as below.
Thanks.
Yan
Re: Percentage node
Reply #1 - Nov 29th, 2012 at 7:08am
Yes, use a custom-drawn ShapeNode or a derived node class that implements the Draw method like this:
using System.Drawing;
using MindFusion.Diagramming;
using MindFusion.Drawing;
namespace MyApp
	class PercentageNode : DiagramNode
		public PercentageNode(Diagram parent) : base(parent)
			Value = 50;
			base.Font = new Font("Arial", 10);
		public override void DrawLocal(IGraphics graphics, RenderOptions options)
			// draw background
			var rect = GetLocalBounds();
			graphics.FillRectangle(Brushes.White, rect);
			// draw progress
			var valueRect = rect;
			valueRect.Width *= Value / 100;
			graphics.FillRectangle(Brushes.Green, valueRect);
			// draw frame
			graphics.DrawRectangle(Pens.Black, rect);
			// value label
			var format = new StringFormat
				Alignment = StringAlignment.Near,
				LineAlignment = StringAlignment.Center
			graphics.DrawString(ValueString,
				Font, Brushes.Black, rect.Right + 2, rect.Height / 2, format);
		public override RectangleF GetRepaintRect(bool includeConnected)
			var rect = base.GetRepaintRect(includeConnected);
			rect.Width += 3 + Parent.MeasureString(
				ValueString, Font, int.MaxValue, new StringFormat()).Width;
			return rect;
		public float Value { get; set; }
		private string ValueString
			get { return Value + "%";  }
