Normal Topic Mouse wheel operation not supported in diagramView? (Read 1850 times)
Kyle Chen
Nov 29th, 2012 at 10:55pm
Is there any way to enable mouse wheel operation in winform diagram view? Thanks.
Re: Mouse wheel operation not supported in diagramView?
Reply #1 - Nov 30th, 2012 at 6:12am
DiagramView inherits a MouseWheel event from the base Control class, but Microsoft have marked it as non-browsable, so you can't attach a handler from the form editor:
[Browsable(false), EditorBrowsable(EditorBrowsableState.Advanced)]
public event MouseEventHandler MouseWheel
Instead, add a handler from code:
diagramView.MouseWheel += OnMouseWheel;
private void OnMouseWheel(object sender, MouseEventArgs e)
Kyle Chen
Reply #2 - Nov 30th, 2012 at 3:07pm
Yep, I figured it out after post. Thank you!
