Normal Topic Issues upgrading from 5.3 to 6.0 (Read 1023 times)
dhaval
Dec 6th, 2012 at 11:52pm
I am planning to upgrade from mind fusion diagramming 5.3 to 6.0 (for windows form application).
I have a diagram with control nodes connected by links.
I changed the reference to use 6.0 and changed the events/properties to fix compile errors.
The code to draw the nodes and links remain the same. Yet the diagram drawn is very different.
There are two major diference:
1. In 5.3 if a node had multiple incoming nodes, they aggregated together as one thicker link. Whereas, in 6.0 they are all separate. Refer to 1 in attached image.
2. If a link has multiple labels, the labels overlap each other. Refer to 2 in attached image.
Let me know if you need more info from my side.
Re: Issues upgrading from 5.3 to 6.0
Reply #1 - Dec 7th, 2012 at 7:00am
1. Are you using some of the built-in layout algorithms?
2. There was no support for multiple labels per link in version 5.3.2. Are you using attached nodes or link custom drawing to draw the labels? You could try replacing that with the new DiagramLink.AddLabel method, using the LinkLabel.AutoArrange option or specifying your own label positions.
