Normal Topic How to color total shape when Elements templates are used in it (Read 9356 times)
Chetna Tumme
Dec 11th, 2012 at 6:50am
I have created a Shape as follows:
var shape = new Shape(
new ElementTemplate[]
new LineTemplate(3, 27, 95, 27),
new LineTemplate(95, 27, 95, 100),
new LineTemplate(95, 100, 3, 100),
new LineTemplate(3, 100, 3, 27)
new LineTemplate(17, 15, 107, 15),
new LineTemplate(107, 15, 107, 88),
new LineTemplate(3, 27, 17, 14),
new LineTemplate(107, 15, 95, 27),
new LineTemplate(106, 88, 95, 100)
null,
FillRule.EvenOdd, "Node");
and then assigned to to ShapeNode & added into the diagram:
var shapeNode = new ShapeNode
Shape = shape,
Bounds = new Rect(60, 60, 50, 50),
Name = "Node",
Text = "Node",
Brush = new SolidColorBrush(){Color = Colors.Magenta}
mindFusionDiagram.Nodes.Add(shapeNode);
My issue is as Follows:---
1. When there are two Element Template []in shape constructor, I think those many regions are created.
2. When I try to color the ShapeNode, only one Rectangle gets colored, other part remians white.
Please let me know the issue in my code or the solution to it as soon as possible.
Re: How to color total shape when Elements templates are used in it
Reply #1 - Dec 11th, 2012 at 8:12am
The second array contains so called decoration lines, which are not parts of the shape outline and are drawn independently from each other. Rearrange the arrays a bit to move most of the elements to the outline and leave only three internal lines as decorations:
            new LineTemplate(3, 27, 3, 100),
            new LineTemplate(3, 100, 95, 100),
            new LineTemplate(95, 100, 107, 88),
            new LineTemplate(107, 88, 107, 15),
            new LineTemplate(107, 15, 17, 15),
            new LineTemplate(17, 15, 3, 27)
            new LineTemplate(95, 27, 107, 15)
    null,
Chetna Tumme
Reply #2 - Dec 11th, 2012 at 9:00am
Hello Stoyan,
your solution hepled a lot. But one thing I am confused about is,
1. WHat is the use of two Element Templates in Shape...
Because I am facing issue in applying dash style in to Line Template in First Element Template of Shape constructor.
Where as Line Template in Second Template gets applied in correct ways.
2. Second issue is, now we had all Line templates in Element Templates. But what if I have Round Rect in first Element Template, and second Element Template contains Line Templates.
Then how I can draw the bounderies...
My shape of "Device" is as follows...
                                new RoundRectangleTemplate(3, 2, 100, 100, 6f),
                                new LineTemplate(2, 116, 103, 116),
                                new LineTemplate(103, 116, 89, 102),
                                new LineTemplate(1, 116, 15, 102)
                        null,
                        FillRule.Nonzero, "Device");
Please tell me how I can create the shape.. Because in above shape, color given was applied only to Round Rect and not to below part.
Please see into it.
Reply #3 - Dec 11th, 2012 at 11:39am
1. The first array is used to specify the node's outline / contour, which is considered the main part of the node and is used for hit-testing, aligning links to it, etc. It's also the part filled using the node's Brush. The second array defines decoration lines; they are not considered when hit-testing and are drawn independently from each other; they won't be filled even if the array defines a closed figure. There's an optional third array that can be specified to define text area; if you omit it, the text is drawn inside the outline area defined through first array. You can also specify additional filled figures via the ShapeDecoration arrays accepted by some overloaded Shape constructors.
2. The outline array should specify a closed figure, try the code below:
new Shape(
                        new LineTemplate(10, 0, 90, 0),
                        new ArcTemplate(80, 0, 20, 20, -90, 90),
                        new LineTemplate(100, 10, 100, 90),
                        new ArcTemplate(80, 80, 20, 20, 0, 90),
                        new LineTemplate(90, 100, 80, 100),
                        new LineTemplate(80, 100, 100, 115),
                        new LineTemplate(100, 115, 0, 115),
                        new LineTemplate(0, 115, 20, 100),
                        new LineTemplate(20, 100, 10, 100),
                        new ArcTemplate(0, 80, 20, 20, 90, 90),
                        new LineTemplate(0, 90, 0, 10),
                        new ArcTemplate(0, 0, 20, 20, 180, 90)
            null, null,
Add a single decoration line as second argument if you need to delimit the round rectangle from the base figure.
Chetna Tumme
Reply #4 - Dec 11th, 2012 at 11:48am
Thanks a lot Stoyan for your solution.
Chetna Tumme
Reply #5 - Dec 11th, 2012 at 12:30pm
Hello Stoyan,
I really need help in creating shape as there in attached file.
Please reply asap.
Reply #6 - Dec 11th, 2012 at 1:04pm
            new ArcTemplate(0, 0, 60, 100, -62, 360),
            new ArcTemplate(40, 0, 60, 100, -118, 360),
        FillRule.Nonzero, "Circles");
