Normal Topic make a newly created node selected (Read 2748 times)
hans
Dec 16th, 2012 at 10:12am
When I create a shapenode by this javascript, the newly creatred node doesn't get selected.
Instead the created link is always selected.
Is there a way to get around?
I also tried: destNode.setSelected(true), but without success.
function onLinkCreated(diagram, args) {
    // get info about the DiagramLink just created
    var link = args.getLink();
    var points = link.getControlPoints();
    var destPoint = points.get(points.size() - 1);
    var orgNode = link.getOrigin();
    var dest = link.getDestination();
    var destNode;
    if (!dest.getClass().toString().match("ShapeNode")) {
        // create a new ShapeNode
        destNode = diagram1.getFactory().createShapeNode(destPoint.getX(), destPoint.getY(), 50, 6);
    diagram1.getSelection().clear();
    diagram1.getSelection().addItem(destNode);
Re: make a newly created node selected
Reply #1 - Dec 17th, 2012 at 7:20am
Are you using the JDiagram's Java applet? In such case, try disabling the SelectAfterCreate property, or otherwise the applet will automatically select newly created items after raising their created event. At this time items are not automatically selected in our JavaScript diagramming library.
hans
Reply #2 - Dec 18th, 2012 at 9:19am
Thanks Stoyan,
This helped.
Hans
