Normal Topic Hit test override for anchior pattern? (Read 1349 times)
j poz
Dec 17th, 2012 at 3:35pm
Is it possible to override the method that determines whether or not we should be allowed to drag/draw a connector from a shapenode's anchor point?
The problem is that when a user attempts to draw from an anchor point, and their cursor is merely 1 or 2 pixels below it, it doesn't register that they want to drag that node.
Rather than adding arbitrary padding to the entire node, I'd like to just override the hit method...
Re: Hit test override for anchior pattern?
Reply #1 - Dec 17th, 2012 at 6:21pm
You could use one of these behavior classes as a model:
http://mindfusion.eu/Forum/YaBB.pl?num=1282737732/1#1
http://mindfusion.eu/Forum/YaBB.pl?num=1250499561/7#7
If you need to allow drawing links from outside nodes, use the GetNodeAt(point, threshold) method to find the origin node.
