Normal Topic outgoinglinks and incominglinks (Read 1513 times)
Ivan Gamo
Dec 19th, 2012 at 5:25pm
hi. i want to know how to work with incoming and outgoing links? because I'm creating a flowcharting diagram. and i want to know how the links working. thnks in advance! Smiley
Re: outgoinglinks and incominglinks
Reply #1 - Dec 19th, 2012 at 6:06pm
You can access node's links via the OutgoingLinks and IncomingLinks collections. If the nodes are tables with ConnectionStyle set to Rows, links will be in the respective Row object collections instead in the node's ones, or you could use GetAllIncomingLinks and GetAllOutgoingLinks methods to get links for all rows. If you don't care about link directions, you could call node.GetAllLinks() to get a list of both in- and out- links.
Here's some sample code showing a couple of ways to access neighbor nodes - via the link collections or the Query method:
private void diagram_NodeClicked(object sender, NodeEventArgs e)
	if (e.MouseButton == MouseButton.Left)
		foreach (var link in e.Node.OutgoingLinks)
			link.Destination.Brush = new SolidBrush(Color.LightGreen);
		foreach (var link in e.Node.IncomingLinks)
			link.Origin.Brush = new SolidBrush(Color.LightBlue);
	if (e.MouseButton == MouseButton.Right)
		foreach (var node in e.Node.Query("outlinks/destination"))
			node.Brush = new SolidBrush(Color.LightGreen);
		foreach (var node in e.Node.Query("inlinks/origin"))
			node.Brush = new SolidBrush(Color.LightBlue);
Ivan Gamo
Reply #2 - Dec 20th, 2012 at 10:06am
Thnak you stoyan. Grin
