Normal Topic Error installing on a WIndows8 VM (Read 5163 times)
Sabrina C.
Dec 20th, 2012 at 9:22am
I've just downloaded my registered version of WPF diagram.
At the moment the primary environment in which I develop is Windows 7 but the Diagramming components have been bought to start developing a new APP for windows 8 so I've installed a Virtual box VM with Windows 8 PRO 64 bit, unfortunately trying to install WPF Diagram on it I receive an error message:
Error 1001: InstallUtilLib.dll: Unknown error.
Is there something that has to be set on the virtual machine to install WPF Diagram?
If you have any clue...
Thank you in advance
Regards
Sabrina
Re: Error installing on a WIndows8 VM
Reply #1 - Dec 20th, 2012 at 11:54am
The diagram's msi installer uses some custom actions built against .NET 2, which might not run on the .NET 4.5 runtime that comes with Windows 8. Try installing .NET 2 first to see if it will help:
http://www.microsoft.com/en-us/download/details.aspx?id=1639
Sabrina C.
Reply #2 - Jan 2nd, 2013 at 1:40pm
Sorry to be late, but I've seen the answer only this morning.
After the installation of framework 2.0 (even if there were 3.5 and 4.0) the installation on the Windows 8 VM was successful.
Thank You.
Stoyo wrote on Dec 20th, 2012 at 11:54am:
