Normal Topic accessing link problems (Read 3758 times)
Ivan Gamo
Dec 21st, 2012 at 3:21am
I'm creating a program that will generate the text in every shape within the flowchart. here is the example of flowchart that I've created.
Ivan Gamo
Re: accessing link problems
Reply #1 - Dec 21st, 2012 at 3:25am
now here is the text that generated from the flowchart above. as you can see the num3 = 3 and num4 = 4 was not generated.
Reply #2 - Dec 21st, 2012 at 11:30am
Check the GenerateHtml method in the SiteMap sample project. It shows how to traverse a flowchart recursively by following links in each node's OutgoingLinks collection.
Ivan Gamo
Reply #3 - Dec 21st, 2012 at 1:32pm
where is it? would you send me the link pleas? thanks.
Reply #4 - Dec 21st, 2012 at 2:24pm
It is somewhere under the Flowchart.NET's installation folder if you have selected to install samples for some Visual Studio version (on one of the first pages of the installer). If you haven't, look for a samples.zip under the Setup subfolder of the installation root folder and extract the samples from there.
Ivan Gamo
Reply #5 - Dec 22nd, 2012 at 8:28am
i found it. but the codes is in php/HTML. i'm using vb.net.
Reply #6 - Dec 22nd, 2012 at 1:57pm
Take a look again. While GenerateHtml creates some HTML code, it is still in VB.NET, and you can see how to traverse the flowchart recursively from it. If you remove all "html +=" lines and add a single Debug.WriteLine call showing current node's text (the root argument), you should get console output similar to what you need.
« Last Edit: Dec 24th, 2012 at 7:30am by Stoyo »
