Normal Topic load_diagram exeption: Unsupported file format (Read 2871 times)
hans
Dec 28th, 2012 at 10:42am
I have a problem with saving and loading a diagram to  and from stream.
I use this code:
saving the diagram
     string SaveDiagram = _EditReference + ".dgr";
     stream = new MemoryStream();
     DiagramView1.Diagram.SaveToStream(stream);
     imageBytes = stream.GetBuffer();
     stream.Seek(0, SeekOrigin.Begin);
     CloudBlockBlob blob3 = BlobContainer.GetBlockBlobReference(SaveDiagram);
     blob3.UploadFromStream(stream);
     stream.Close();
loading the diagram
     CloudBlockBlob blob = BlobContainer.GetBlockBlobReference(SavedDiagram);
     blob.FetchAttributes();
     MemoryStream m = new MemoryStream();
     blob.DownloadToStream(m);
     DiagramView1.Diagram.LoadFromStream(m);
results in: load_diagram exeption: Unsupported file format
When I first download the blob to a file and then loadFromFile it works well.
Is loadFromStream not supported for memorystreams ?
Re: load_diagram exeption: Unsupported file format
Reply #1 - Dec 28th, 2012 at 10:57am
Diagram's LoadFromStream method starts reading from the stream's current position, and blob.DownloadToStream(m) might be moving it to the end. Try seeking to the stream's origin before calling LoadFromStream.
hans
Reply #2 - Dec 29th, 2012 at 10:24am
Thanks Stoyan,
It helped.
I always get great help from you.
Thanks again.
Hans
