Normal Topic Diagramming for JavaScript, V1.4 (Read 2503 times)
Jan 2nd, 2013 at 2:55pm
We have released version 1.4 of MindFusion.Diagramming for JavaScript. It contains the following new features:
Table Nodes
A TableNode displays tabular data, and can be used to represent table schemas in database diagrams or classes in class-hierarchies. A table contains cells arranged in a grid, and every cell can display text and/or image. Cells, columns and rows can be customized in various ways - there are properties available for setting their extents, style, image and text alignment. The number of cells in a table's grid can be programmatically changed by calling methods such as redimTable, insertRow and insertColumn. If a table contains many rows, you can let users scroll them up or down by calling the setScrollable method.
Container Nodes
A ContainerNode can contain other diagram nodes. When a container is moved, its child nodes move too. Containers can be nested one within another to unlimited depth. They can be folded to a smaller size, hiding their child items, and unfolded to show content again. Nodes inside a container can be linked to nodes both inside and outside of it. If a link connects items in the same container, the container is not considered an obstacle by the auto-routing algorithm.
~ The Locked property can be used to disable interaction with a diagram item.
~ Improved rendering speed when changing items' appearance properties.
