Normal Topic Store Custom Data with the Tag of a ShapeNode (Read 3848 times)
Anoop C M
Jan 4th, 2013 at 10:22pm
I wanted to store some custom data as json object to each of the nodes. I tried to use the Tag object but apparently it failed with a message "split" function not found.
How can we do this?
Also as I see the Tag is currently used to show the title in the NodeListView. Can we have a seperate object property to store custom data.
I know Diagram  has the SerializeTag/DeserializeTag but that is only useful for Saving/Loading.
Re: Store Custom Data with the Tag of a ShapeNode
Reply #1 - Jan 7th, 2013 at 9:23am
For items in the diagram you can set Tag to any object with simple values; they will be serialized to Json automatically by the framework's built-in JavaScriptSerializer.
// on server
node.Tag = new { Prop1 = "Val1", Prop2 = "Val2" };
// on client
function onNodeClicked(sender, args)
    alert(args.getNode().getTag().Prop1);
Indeed the NodeListView uses Tag to transfer caption values to the client side, so you can't assign tags to its nodes at this time. We'll add a separate property for captions in the next release.
Anoop C M
Reply #2 - Jan 7th, 2013 at 4:29pm
Thanks Stoyan. That helps confirm.
If you set the tag for the NodeListView then it fails so it is a bug right now. Good to hear that you will proactively add a new property to fix it.
Anoop
