Normal Topic Buttonimage (Read 2779 times)
Pat
Buttonimage
Jan 9th, 2013 at 3:45pm
What is the standard size for buttonimage.scroll image?
What color is used as transparent color?
Re: Buttonimage
Reply #1 - Jan 9th, 2013 at 6:20pm
There is no standard size, the control will draw that image unstretched and aligned to the middle right of the table's caption bar. You will probably want to match the image height to the table's CaptionHeight value. Use a .gif or .ico file for transparency.
