Normal Topic On the diagram to select multiple objects do to appear an edit box instead of multiple (Read 2503 times)
Joe
Jan 11th, 2013 at 2:21am
Re: On the diagram to select multiple objects do to appear an edit box instead of multiple
Reply #1 - Jan 11th, 2013 at 6:51am
Are you asking how to show an edit box after selecting multiple objects?
Joe
Reply #2 - Jan 12th, 2013 at 9:30am
yes
Reply #3 - Jan 14th, 2013 at 7:42am
You could add an edit box to the diagram as a node and place it at the location of the selection rectangle:
DiagramNodeAdapter editNode;
private void OnSelectionChanged(object sender, EventArgs e)
	if (editNode == null && diagram.Selection.Items.Count > 1)
		var editBox = new TextBox();
		editNode = new DiagramNodeAdapter(diagram, editBox);
		editNode.SizeSyncMode = SizeSyncMode.SetSize;
		diagram.Nodes.Add(editNode);
		editNode.Bounds = diagram.Selection.Bounds;
		diagram.SelectionOnTop = false;
		editBox.Focus();
Then remove the node when the diagram is clicked, or from other event handler such as KeyDown raised for Esc or Enter keys in the edit box.
private void OnDiagramClicked(object sender, DiagramEventArgs e)
	if (editNode != null)
		diagram.Nodes.Remove(editNode);
		editNode = null;
