Normal Topic SuspendLayout does not suspend everything... (Read 4020 times)
Achim
MindFusion rocks!
Jan 14th, 2013 at 1:10pm
Hi there,
i'm using the ResourceView and have about 20-30 Resources to be drawn which takes about 5-10 seconds. So I wanted to uses SuspendLayout() and ResumeLayout() but this produces weird results.
As you can see in the screenshot attached the vertical scrollbar goes to the left and shrinks continuously until the loading process is finished and ResumeLayout() is called.
Am I wrong or shouldn't the control be absolutely "quiet" as long as the layout logic is suspended? Or have I forgotten to do something other needed?
Best regards and thanks for any help
Achim
Re: SuspendLayout does not suspend everything...
Reply #1 - Jan 14th, 2013 at 1:29pm
SuspendLayout and ResumeLayout are not supported. Try using BeginInit/EndInit instead.
Achim
MindFusion rocks!
Reply #2 - Jan 14th, 2013 at 1:47pm
Thank you. This works as expected.
Achim
