Normal Topic Trial Version problem (Read 1931 times)
Ivan Gamo
Jan 15th, 2013 at 4:30pm
Sometimes the text of every nodes in the diagramview became "Trial Version" is there any way to disable it? please..  Sad
Re: Trial Version problem
Reply #1 - Jan 15th, 2013 at 5:40pm
If you have installed the licensed version, remove the mindfusion.* references from your project and add references to the assemblies from the new installation folder. If you are still evaluating, the texts in your diagram are not lost - you can save the file and they will appear correctly after restarting the application.
