Hot Topic (More than 10 Replies) WmfExporter does not render controlNodes (Read 8926 times)
jf2020
I love FlowChart!
Jan 15th, 2013 at 10:37pm
I'm having an issue with WmfExporter which does not render ControlNodes. The PaintControl event that I have for the drawing of the controlNode is not called when doing the WmfExport. Am I missing something? I couldn't find any render options to get it to work.
JF
Re: WmfExporter does not render controlNodes
Reply #1 - Jan 16th, 2013 at 9:34am
If you have the source code, set renderOptions.PaintControls = true in WmfExporter.Export. We'll add this for next release.
jf2020
I love FlowChart!
Reply #2 - Jan 16th, 2013 at 3:22pm
Hi Stoyan,
Thanks for the answer! Yes we do have the source code but our internal policy prevents me to do changes to vendor components.  Can you please send me the updated Export.Wmf.dll?  We are currently using 5.8.0.19078.  It would really help me to get this solved ASAP.
JF
Reply #3 - Jan 17th, 2013 at 7:17am
Use this class to export then:
class DiagramEx : Diagram
	Diagram diagram;
	public DiagramEx(Diagram diagram)
		this.diagram = diagram;
	public override void Draw(IGraphics graphics,
		RenderOptions options, RectangleF clipRect, bool noModifiedItems)
		options.PaintControls = true;
		diagram.Draw(graphics, options, clipRect, noModifiedItems);
wmfExporter.Export(new DiagramEx(diagram), path);
This should also work for PDF and SVG exporters.
jf2020
I love FlowChart!
Reply #4 - Jan 17th, 2013 at 12:14pm
Stoyan,
It works perfect.  Many thanks for the great support
Smiley
JF
jf2020
I love FlowChart!
Reply #5 - Jan 22nd, 2013 at 9:28am
Actually, while this is working great for WMF, it doesn't seem to work for PDF.  I can export fine a diagram that doesn't contain a controlNode, but as soon as I try to export to PDF a diagram with a controlNode using DiagramEx  I get teh following exception
System.Runtime.InteropServices.ExternalException occurred
  HResult=-2147467259
  Message=A generic error occurred in GDI+.
  Source=System.Drawing
  ErrorCode=-2147467259
  StackTrace:
       at System.Drawing.Bitmap.LockBits(Rectangle rect, ImageLockMode flags, PixelFormat format, BitmapData bitmapData)
       at System.Drawing.Bitmap.LockBits(Rectangle rect, ImageLockMode flags, PixelFormat format)
       at MindFusion.Pdf.Tools.x3e30ee412360b69f(Bitmap xe058541ca798c059, Boolean x5ffbb4b34fae8a48)
       at MindFusion.Pdf.Tools.GetImageContentEx(Image imagesrc, Boolean IsGrayscale)
       at MindFusion.Pdf.PdfImage.GetContent()
       at MindFusion.Pdf.PdfObject.Save(PDFWriter writer)
       at MindFusion.Pdf.PdfPage.Save(PDFWriter writer)
       at MindFusion.Pdf.PdfDocument.Save(String fileName)
       at MindFusion.Pdf.PdfGraphics.SaveContent()
       at MindFusion.Pdf.PdfGraphics.Dispose()
       at MindFusion.Diagramming.Export.PdfExporter.Export(Diagram diagram, String filePath)
       at NATO.EB.Client.Views.Sketchpad2.SketchpadDiagram2.Export2PDF()
  InnerException:
Reply #6 - Jan 22nd, 2013 at 10:32am
What does your PaintControl handler look like?
jf2020
I love FlowChart!
Reply #7 - Jan 22nd, 2013 at 12:31pm
Here it is:
Code (C++)
        private void flowChart_PaintControlHost(object sender, PaintControlEventArgs e)
            e.Handled = false;
            var graphControl = e.Node.Control as MsChartBaseControl;
            if (graphControl != null)
                var paintRect = diagramView.DocToClient(e.PaintRect);
                var bmp = graphControl.GetBitmap(paintRect.Size.Width, paintRect.Size.Height);
                e.Graphics.DrawImage(bmp, e.PaintRect);
                bmp.Dispose();
                e.Handled = true;
Reply #8 - Jan 22nd, 2013 at 12:59pm
Try commenting out the bmp.Dispose line to see if it will fix the problem. If it does, you will have to dispose the images only after the PDF is saved.
jf2020
I love FlowChart!
Reply #9 - Jan 22nd, 2013 at 1:31pm
No luck. It throws the same exception when commenting that line.
Reply #10 - Jan 22nd, 2013 at 2:29pm
PdfGraphics.DrawImage works without problems in my test when drawing an image loaded from a file, so I suppose the image object returned by MsChartBaseControl.GetBitmap might be locked in some way and doesn't allow access to the bitmap bytes. Check if the work-arounds for unlocking images shown here will help:
http://www.kerrywong.com/2007/11/15/understanding-a-generic-error-occurred-in-gd...
The first one seems wrong though, I think the order should be slightly different:
Bitmap bmpNew = new Bitmap(bmp);
g = Graphics.FromImage(bmpNew);
g.DrawImage(bmp, new Point(0, 0));
jf2020
I love FlowChart!
Reply #11 - Jan 22nd, 2013 at 5:50pm
Yes! this solves the issue:
Code (C++)
            e.Handled = false;
                var bmpNew = new Bitmap(bmp);
                var g = Graphics.FromImage(bmpNew);
                g.Dispose();
                bmp.Dispose();
                e.Graphics.DrawImage(bmpNew, e.PaintRect);
                bmpNew.Dispose();
                e.Handled = true;
jf2020
I love FlowChart!
Reply #12 - Jan 23rd, 2013 at 2:22pm
Stoyan,
Using DiagramEx only kind of works. I have issues with the clipping which is not the same when doing the export directly through the initial or with DiagramEx. I tried to see if the bounds could be incorrectly set but I just stopped and I have now build the WMFExporter and PDFExporter dlls from teh source code with the additional RenderOptions as you initially suggested. This works with no issues so far. I have also made RenderOptions a public property of both exporters. Why not do that instead of providing specific properties as you do in PDFExporter Smiley?
JF
Reply #13 - Jan 24th, 2013 at 12:05pm
I suppose DocToClient might not be working correctly for the second diagram if the view is scrolled or zoomed. We'll add export options properties for next release.
