Normal Topic Get per line of text in shapenmode.text (Read 3337 times)
Ivan Gamo
Jan 16th, 2013 at 5:13am
how to get per line of text in diagramview shapenode.text?
the Environment.NewLine doesnt's work!
Re: Get per line of text in shapenmode.text
Reply #1 - Jan 16th, 2013 at 8:19am
It works in my test:
var n = diagram.Factory.CreateShapeNode(50, 50, 100, 50);
n.Text = "line1" + Environment.NewLine + "line2";
//n.EnableStyledText = true;
Have you set any flags in node.TextFormat?
Ivan Gamo
Reply #2 - Jan 16th, 2013 at 11:31am
sorry for incomplete explanation but i want to get or split  every new line of text inside the node and store it in array like for example the node name is shapeini and the array name is txtPerLine
txtPerLine = shapeini.text.Split(Environment.NewLine)
thanks.
Ivan Gamo
Reply #3 - Jan 16th, 2013 at 11:32am
no i haven't set any flags in node.TextFormat
Reply #4 - Jan 16th, 2013 at 1:27pm
The Split method expects an array of delimiter strings:
var lines = node.Text.Split(new[] { Environment.NewLine }, StringSplitOptions.None);
This will let you find new lines entered by the user when editing, but not the line wrap positions used when long text is wrapped at node borders.
Ivan Gamo
Reply #5 - Jan 17th, 2013 at 6:18pm
Thanks Stoyan. Grin
