Normal Topic shapeNode.Bounds are lost when using setShape (Read 2110 times)
hans
Jan 19th, 2013 at 1:41pm
When I use node.setShape(shape) and then diagram.repaint(), the changed node gets really big.
I workaround with:
var savedBounds = node.getBounds();
node.setShape(shapeID);
node.setBounds(savedBounds)
But shouln't bounds stay the same?
Also when I use:
node.setBrush(newbrush)
node.setTextColor(c)
the canges are only visible after using diagram.repaint().
Is this intended behaviour?
Re: shapeNode.Bounds are lost when using setShape
Reply #1 - Jan 20th, 2013 at 10:29am
setShape does not invalidate the node correctly. Use this as a work-around instead, to avoid repainting the whole diagram:
node.setShape(shapeId);
node.invalidate();
or move the setShape methods before the brush / color setter calls.
