Normal Topic Shadow or halo effect wanted for single composite node (Read 3644 times)
Rennie
Jan 20th, 2013 at 5:47pm
I've tried various things but I can't get the shadow effect to work at all. I've even tried downloading the Telephony sample from this thread http://mindfusion.eu/Forum/YaBB.pl?num=1342176733, but it must be for a previous version, as I'm getting 15 compiler errors. Anyway, that is apparently for ShapeNodes, and what I need is for CompositeNode.
What I'd actually like is more of a halo effect, with a colored shadow all around the node, like with the Aero effect. But again, I need it to be for one node only, and it's a composite node.
Hope you have a suggestion, thanks.
Re: Shadow or halo effect wanted for single composite node
Reply #1 - Jan 21st, 2013 at 7:08am
We have implemented support for effects in composite nodes just recently, it will be available in an official release in a couple of weeks:
http://mindfusion.eu/Forum/YaBB.pl?num=1352371257/3#3
Rennie
Reply #2 - Jan 21st, 2013 at 8:29am
OK, sounds good, thanks.
Rennie
Reply #3 - Jan 29th, 2013 at 11:50pm
I've started using the Aero effect to provide a "halo" around my composite node (using 6.0.2 beta) by specifying the shade color as yellow. This is working OK, but I'm wondering if it's possible to make the shading size larger?
Reply #4 - Jan 30th, 2013 at 7:11am
It's not possible at this time, and the shade drawing is also very expensive in processing time so you'll probably not like the performance with larger shades Smiley
Rennie
Reply #5 - Jan 30th, 2013 at 9:50am
Aw, now I'm feeling disappointed.    Cry
How about if I promise that I'll only apply it to one node, and not apply any effects at all to the other nodes?  Roll Eyes
Rennie
Reply #6 - Jan 30th, 2013 at 10:30am
Maybe I shouldn't be using the Aero effect at all. I just want to mark one node with some kind of yellowish frame around it, to show that it is selected in a special way.
Maybe I should have an extra outer shape that is hidden or transparent for all nodes except for the one I want to mark, and use a yellow brush for it for the one node I want to mark. Does that sound like a better way of doing what I want to do?
Reply #7 - Jan 30th, 2013 at 2:21pm
We'll have it in mind for next release Smiley A way to draw the frame around the special node is to change its Pen to a thicker one, possibly using the Pen(Brush) constructor with a translucent gradient brush. There are other methods, such as drawing using the GDI+ API from DrawBackground or DrawForeground event handler.
