Hello i have a problem with the node distance in the LayerdLayout.
I'm using Horizontal Orientation.
If there are only a few nodes everything is working allright. But if there are some more Nodes then the result looks very ugly.
My links are all AutoRoute = True
And the layout is created like this:
layeredLt.Orientation = Layout.Orientation.Horizontal
layeredLt.NodeDistance = 15
layeredLt.LayerDistance = 35
layeredLt.IgnoreNodeSize = False
layeredLt.SplitLayers = False
layeredLt.Margins = New System.Drawing.SizeF(15, 30)
layeredLt.Arrange(diagramm)
Now i tried a lot of other values and other functions but I'm not able to get a better result.
As you can see in the Attachment there is a far distance between the "node groups" and because of that everything is really small.
It would be great if everything could be closer to each other, that it doesn't use that much place.
Well now i can zoom in but I have to scroll a lot and I'm not getting much information on the first view, because everything is split so far.
