Normal Topic Moving shapenodes programatically (Read 1207 times)
frankinstien
Jan 21st, 2013 at 11:00am
Is there a way to move shape nodes programmatically without causing each move of a node to invalidate the screen?
Re: Moving shapenodes programatically
Reply #1 - Jan 21st, 2013 at 2:29pm
Moving a node only marks the area for repainting by calling Control.Invalidate, but the actual drawing code is called only when the application becomes idle and receives a WM_PAINT massage from the OS. If you want to prevent the Invalidate call for some reason, you can override the Diagram.OnRepaint method and do not call base.OnRepaint when invalidation is suspended.
